skorped-t5
Hi. I have for a long time read that a newer secondary clutch ,fitt vmax 500 1994.
What year should i look for,to put on my sleed? Is there some more parts i need to change ,when putting on a newer clutch?
/ Tomas
/ Tomas
Maim
Super Moderator
Look over on ty4stroke.com as that is a mod for the phazer
skorped-t5
I cant find it, can you post a link to it?
/Tomas
opsled
skorped-t5
95/96 Vmax-500/600 is what you want for your 94. Also fits Phazer, SRX and 540 Vamx.
Pic is of 95 Vmax 600 setup on 87 540 Vmax.
Do i need something more than the secundary clutch? Like driveshaft or somehing from gearbox?
Maim
Super Moderator
https://ty4stroke.com/threads/the-new-secondary-brain-child-is-done-and-is-easy-to-do.101732/
here is how to put secondary from any sled but fx nitro and sr viper onto your sled.
all you need is a secondary and some time at the machine shop. will be doing the mod at some point when i run out of secondarys to fit.
opsled
No, Not if you use the 95/96 Vmax secondary. You will need a longer retaining bolt and spacer. Either go to hardware store for a longer bolt and make the spacer (easy) or buy new/used from 96-99 Phazer.
Use any other Yamaha secondary of this type and you will have to modify spline depth and offset as Maim is showing with that link.
95/96 Vmax 5/600 secondary is correct for your 94.
opsled
