Fuse box
SkiGroomer
Manitoba
I have just bought a used 2011 Venture lite with a mere 1000 k’s on it and my accessory fuse has blown (owner’s ignorance, turns out you should put the cap on it in a snow storm). I have located the tiny fuse box beside the battery. Nestled to the fuse box is another 3 x 1 case labelled gear, spare, spare with a 15 amp fuse and two 4 amp fuses. I am not sure which of the fuses in the main box is for the accessory plug. Also, between the main fuse box and the little 3 x 1 case there appears to be an empty spot that could house a fuse?!? Hoping someone with a bigger brain in their head than me can help me out with what fuse is for the accessory, what the little 3 x 1 case is all about, and what the empty spot in the main fuse box could be. Many thanks in advanceC4F1BA0D-B867-4D39-9386-F85F476FEDF1.jpg
Hi and welcome to the site. You will want to register and ask this question over on the 4 stroke side. This is the 2 stroke side. A lot more info over ther!
