2000 srx gearbox center to center distance
micorps
Fountain, co
Hi all been awhile. I am trying to find the center to center distance for the gearbox in my 2000 srx. I am trying to buy a chain for my 23/35 and 23/37 gears i am going to have my brother try. Please let me know if you know the cd. Tough doing this from 2,000 miles away. Thank you. Tim
Thank you for the responses. Finally got my brother and dad to remove can and pipes lastnight to measure. They came up with 7 1/16 to 1/8. The chart captnviper helps alot with stock part numbers. I bought a 23 and 24 top and 35 and 37 bottom. Will see how my existing 68 chain fits if we run the 23/35, may need next size smaller chain. The 68 chain should be good for the 23/37 gears. The back story is this is one of my speed run sleds. We were trying different setups not realizing oil pump was going and cylinders going down as a result. Finally figured it out when it was too late. Now it has a fresh motor and previous setups are not right, topping out at around 600-700ft with 22/39 gears, which was surprised it had that gear ratio when i bought it and still ran a best of 107mph on speed traps. New motor is still coming in also, so definitely need some gearing for more top end. Anyways, thank you for the responses. Tim
