Randy Pro
Has There Been Anyone Put A 2000 Stator Off A Srx Or A Viper In To A 98srx For The Reson For The Brighter Light And Tail Light???
sxviper32
can you do that? if so, whats the best stator you could go with for the most power in a srx? thanks!!!
800
its not just the stator, you need to move the pick up coil, a flywheel and the whole wiring harness and electrical components as well as the headlight assy.
yamaholic22
he's right, it can be done but its a lot of horsing around
Randy Pro
stator
thanks for the info 800. just wonding if it could be done for a brighter lighting. sonds like to much work and money
If you are looking for a brighter headlight try PIAA Xtreme white.They use the same power but really light up bright.
