Clutching help/opinions
Yamitriple
Ovid Michigan
Using power inc center dump pipes with no addition mods I have 89l weights with 6.1 g rivets in the only hole, sled pulls nicely at top end but is lacking in mid range. Belt is NOT making it all the way to the top of primary, and back shift is lacking. Has a bog when trying to get back onto it. Secondary I have a 45 straight angle in thinking it would clear up bog. Was running a 46/41 black diamond but haven’t tested it since upping my rivets from 4.5 to 6.1. Sleds rpms are at 8150-8200 strong. Any opinions?
Oh and I have standard primary spring, 15 mm rollers with 1 engagement shim, secondary has standard spring set to 60 wrap. Sled engagement is fairly low at 3600-3800
