What should compression numbers be on this motor.
Going to check tomorrow
Vincent
110 and over is good
My triple has almost 18 500kms
And still has 125 across all three.
I checked compression was 120, 120, 120 cold
Will it go up if I checked when warm
Yamitriple
Likely down a little. 120 is good.
super1c
Super Moderator
That’s fine. It’s not so much the number as it is the difference between the cylinders. Your comp is fine.
