srx700pilot
I purchased a 98 srx 700. I let my kids ride the sled around the yard. It runs ok but looses power on higher throttle. Low end seems ok. It went through about 10 gallons of gas after 37 miles. I cleaned the carbs, set air screws @ 1.5 out. I thought maybe a float jet was not seating right but they appear all clean. The carbs in general appear to have some surface varnish in places. Also The old air filter was literally falling apart in pieces. It was almost dust like. What would make it go thru so much fuel so fast? It also seams it has high oil consumption. I’m taking carbs off one more time now. Any help is appreciated. I also replaced plugs because it wasn’t running on all 3. The one thing I noticed is when I pull one of the caps off while running, I get a hefty shock from it every time. Could that contribute to the poor fuel usage? I turned off all lights at night to see if I could see it arching, and didn’t see anything.
