vdubracer33
Not sure if its supposed to happen or what.. But ever since I put spacers in I noticed on a lake run wide open it will go to 8,000 rpms for a while then it will drop down to 7800.
			I would guess clutching components?
Reeds spacers wouldn’t do that unless some petals are shot.
Also, your target RPM should be around 8400.
8000 is very low.
8000 is very low.
A couple of bucks
Clutch related. Remove the six bolts holding the cover on. Inspect for wear and slop.
Back each bolt out 1 turn at at time as the cover is under pressure.
You did remember to put the white stuffers in when the reed blocks went back in didn't you?
vdubracer33
Yes stuffers went back in. Also just noticed the title says drops idle.. Dont know why it wrote that.. Lol i suppose its time to play with the clutch. I never have and have owned the sled for around 6 or 7 years
			vdubracer33
Both my xtc's top out at 8k. Which is weird because I thought I read somewhere that they were revving to high from factory. Any ideas on what to do with clutch like what size weights or color spring and where to get them? Always wanted to do something with the clutch anyways to get more snap out of it.
			What elevation are you at ?
Also, what belt are you running ?
Those should all over rev from the factory, 2 of mine were at 9000 rpm...
the twins want top rpm of 7800. the tripples want a top rpm of 8500 ish in stock form.
			Vincent
Those should all over rev from the factory, 2 of mine were at 9000 rpm.....
X2 both our 700 and 600 triples over reved to 9000 rpms from factory!
							vdubracer33
Not sure of elevation. In New Hampshire. And running the factory 8dn belt.
			vdubracer33
What are the odds.. But maybe both sleds were tuned down a little to drop the revs or something? I just find it odd both sleds do the same thing. One has probably 8,000 miles on it and the other one I picked up 2 years ago and only has like 2500 miles on it. Debating om doing the head gasket mod to the one with 2500 miles
