hereismylife
Need to replace trailing arms on my 01 sxr. Are the viper the same?
Thanks Joe
Thanks Joe
viper has taller spindles than a sxr, so arms are not the same.
hereismylife
So I take it the sxr spindals won't reach the top....
Thank you.
Thank you.
Correct. But, you could use XTC, XT or even SRX, SX trailing arms.
Angles may be slightly different, but should work fine.
Can’t recall what ski stance the sxr has, don’t know if it’s the same as the wider xtc, or the slightly narrower SX.
Whichever is the same as the sxr, would be a direct replacement.
hereismylife
Thank you for the info. At least there are some options.
SRX and SX have a 40.9 Ski Stance
XTC, XT, Vmax, SXR, Viper and Venture have 42.7
Mountain Max is the narrowest
