Chain case bottom gear bolt size
super1c
Super Moderator
Freeland & Otsego lake, MI
Does anyone know size (pitch and thread) of bolt that holds bottom gear onto drive shaft in chain case. Had bolt back out and stripped end of shaft. Need to clean up threads. Bolt also blown out so can’t measure from that. First drive failure I’ve ever had. Looks like oil seal went bad, ran dry and smoked bearing taking out both case halves and a few small parts.
Let me know if ya need a bolt or two, I'll stick them in the mail for you .
Not that you cant find them a the hardware store, but sometimes the larger headed ones are not there.
Wow thanks. We’re still doing inventory on parts at this point, I’ll let ya know if I need anything! Thanks again! Chris
