SRXChris
Still trying to get my sled as back to as close to stock after previous owner did alot of mods to it.
Have the carbs on the bench as I'm changing the jets to bigger from 148.8 148.8 and a 151 to a 150-150-152. Pilots will go to 42.5 from 40, model is 01 SRX with cold air kit. Looks like kit was added and no change to the jetting specs as 148.8 x2 and 151 and 40 pilots are stock specs for mine. Its lean.
Going through manual and carbs and noticed throttle valve height is was off, manual says spec is 1.2 mm. Mines at 5mm + currently. Obviously this needs adjusting and wondering has anyone run this wide of gap before and why? SHould I take it right to spec as manual states? Thanks.
