adding electric start 2000 sxr 700
kastner03
pa
i’ve searched and the only write up i’ve found is for a viper... is it the same process and items needed?
seems like i’ll need
starter
starter harness with relays
battery bracket
battery
primary clutch (or the gear to mount on the back of mine)
Same exact process. They are all interchangeable with the pro action sleds.
are the parts different between the twins and triples? i would assume so but you never know
