Helix bushing, will it scratch the "shaft"?
norwegian
Well-known member
norway
Will a helix bushing scratch the "shaft" its riding on if the bushing is a little scratched? I didn't have a press, so I pounded it on with a hammer and socket, and it got a little bent inwards, I removed my best, but it may not be 100%.
Will it scratch?
The bushing should have a coating on it, if it's just the coating that scratched it shouldn't be a problem. If the coating is worn off you should replace the bushing with a new one. When those bushings get worn things don't work right anymore. I had 3 sleds last year with worn secondary bushings, all 3 sleds had problems with shift RPM, they were revving too high, new bushing brought RPMS back where they needed to be.
