Long shot I know but do these fit 2 stroke sleds like the sxviper? Would they work good on a swing arm front or need double a arm like the newer sleds?
The ones from vectors, nitros and apex just bolt right on with stock rubber. The ones from a sr viper or side winder are taller, so you would need to put a shim into make the stock rubbers work. Never put a sr set on a trailing arm sled but the take offs from my 16 apex xtx are on my brother’s 1997 sx700 in my garage right now. Still working on the sled, so I cannot tell you how they will handle on a trailing arm chassis.
