stealth82
Alright so im replacing the bushings in my no action suspension. My ? Is the 2 bushings that go in the front by the front support by the front shock, each wheel has 2 snap rings. I got the wheel off, now how do i get the bushings off so i can change the bushings? Thanks
Can you post a picture so we see what you are talking about?
super1c
Super Moderator
Not sure where he’s at either. Need a pic or a clearer description.
I think he is talking about the two smallest wheels, that are at the very top of the track.
If i recall, i removed the appropriate snap ring, then hit the shaft they ride on with a plastic type hammer to force the shaft through. Be careful not to mushroom out the shaft.
stealth82
Murder yamaha, yes that sounds about right. But yea today after work ill try and pic to show what im dealing with.
stealth82
I was trying to post a picture from my phone but it wont let me, any suggestions? Thanks
Reduce image size to 1024x768 with phone image resizer app
stealth82
stealth82
So heres the part im talking about. I got the wheel off but the bearing doesnt budge. Im trying to get these off on both sides to change the two bushings
super1c
Super Moderator
They are pressed on. Support in a vice, place a 2x4 over end of shaft so it does not get damages and give it a few good wacks with a man hammer. It will come off, just may have to use some force.
stealth82
Ok. Just sux i dont have a vice but I'll figure it out thanks
if your truck is high enough, use a dead blow hammer with the bearing resting on the edge of your hitch. work bench works aswell.
stealth82
Unfortunately i dont have a truck, but i managed to get one bearing off.
A couple of bucks
Lately I've just been cutting bearings off with an angle grinder & cutoff wheel.
Gave up the fight, huh ?? lol
A couple of bucks
It was a gear shaft from 1962/63 brush hog gearbox. That forker did not come off w/ 20 tons on the press gauge. The cut-off wheel made short work of it.
