viperman70
My set up 8bu 3.1 in both holes,red spring with one shim,engages at 5200.
51/43 Yamaha helix,green Yamaha spr at 80twist, 20/40 gearing
My question is it comes out hard ahead of all the f7s but they will catch me 3/4 track and around me at the finish by a loop.I was going to try a 21top gear and see if it wouldstay ahead the whole way. The video shows some spinning.
Any advise would be appreciated.
Was the only Yamaha and I represented well making it to finals in 700 stock,700imp,800stock.
What RPM you running on top?
Does it climb through the run?
viperman70
Oh sorry forgot the rpm.
It goes right to 8100 but does not climb like it should it feels kinda flat. I always figured if I could get them on holeshot they couldn't catch me.
8100 is way too low, would like to see the initial hit to be around 8300-8400 and maybe climb 200 rpm by the end.
May be too heavy with the rivets, or too weak on primary spring.
viperman70
Yeh Yammiegods set up calls for a max performance white spring 60/130 but no one has one. I tried a new dalton bgb suppose to be 57/135 but it was lower engagement like 4500 and wasn't even close to the red spring. The red spring is not new though. I was going to try a viper cdi box and run the weights empty and stay just below 9000rpm since I just grass drag it.
Don’t think the factory pipes will make power that high, even with the extra timing.
May be best to start with one rivet lighter. Test, and go from there.
Woody255
You want to gain about 300 rpm. Try taking 1-2 grams out of the tips of the weights. I’d rather be 200rpm low then 100rpm high. I definitely like the idea of taller gearing if you are being run down. Keep in mind the SRX was king, until the F7’s came along. A well setup F7 will be a handful! Keep us posted.
viperman70
Yeh when I cut a good light I lead the whole race till 5yds before finish. I ran 21/40 at a earlier race and I was running them down to a sled at the end. It felt like it pulled harder and my clutch set up wasn't dialed in yet. Now the holeshot is amazing but I dont get that normal pull your arms off feel. I'll try the tips empty and see what it does first. Them f7 guys were not happy it was sweet.
A couple of bucks
660 then?
viperman70
660 then?
No 500ft
A couple of bucks
Is that 51/43 Yamaha helix an 8BVFA?
Post #114
https://totallyamaha.net/showthread.php/61494-List-of-aftermarket-helix-angles/page3?highlight=8bvfa
A 51/45 should be in your future.
Dalton is accurate w/ their ramp cutting. Others are off a little. Another manufacturer in particular one is off a lot!!!
Post #114
A couple of bucks
For 500, stick with the 20/40. If any gearing is changed, do you have a 39 to replace the 40? That combination would use the same chain.No 500ft
viperman70
Yes it is a 8bvfa off 03 rx1.
I don't have a 39 bottom gear yet
But it seem to pull real hard last 100ft when I had the 21/40 set up.
Hard to judge when you are that far out of the power though.
Gotta get that rpm up first IMO.
