He wants to add an 2 inch riser.
I have the park brake cable from a 01 ml and the brake hose from the same sled. I think they are a little longer and will fit.
But what about the throttle and oil cable? Will these fit?
https://fatmansparts.com/8-ext-throttle-cable-yam-70-1089-wps
If you re route the lines you can run a 2" riser with no changes to any lines. I have it done on a 2000 SRX and a 2002 Viper.
super1c
Super Moderator
X2. 2” should be no problem.
