Kchud01sxr600
Hello everyone. Hoping someone has seen this before or might have an idea on what's going on. I have a 2002 SXR600 I have had the engine out and cleaned everything up and now I have it back together and when I get it to run I can see sparks below the carbs. It almost looks like it's coming from between the case halves. Nothing looked out of place when I had it out so I'm lost. I'm open to all ideas so let's hear them. Thanks in advance for all the help.
Do you means sparks like when you grind a piece of steel or sparks like voltage is jumping to ground? what color are the sparks?
Kchud01sxr600
After some more digging It looks like i might have a bad ground somewhere. I am seeing arcing where one of the protective springs runs across the steering shaft.
that would be my guess check all the grounds for corrosion. If its electric start check the ground connection at the motor.
Kchud01sxr600
Where are the gounds? I just had it all apart and cleaned everything. But I could have missed something.
I dont have a srx i cant tell you that. The other thing it could be is bad plug wire and or boots. Start it up and turn off the lights if its inside and look for arcing from your plug wires.
Kchud01sxr600
I will give that a try tomorrow. Thanks for the help
MURDER YAMAHA
VIP Life Member
Main ground for wiring harness is above secondary clutch. Black wire with an eyelet end. It’s on the vertical part of the steering gate.
