Bradthedad
New to site looking for help. I have 3 Srxs. 00 ...01.....02....  The 2000 all stock and runs like a champ. I had Hauck go through it as i bought it used. The 2001 I had Hauck put a Set of Aaen pipes ( got cheap from online auction also brand new),and Hauck  clutch kit with extra weights on and 2000 jets/ pilots. Egt gauge to keep an eye on her and 144 Chisels. St. Germain radar run 2019 got embarrassed... MID 80s. Other Srxs were 103.5- 105... Lake Wi 2019  , I brought the 2000, and the 2001. 2000 took first place by 4 mph over my 01.What do I do????????? Stock pipes that helpful?
I would start with power valves.
			Bradthedad
Thats one of the first things I took care of. Trying to prevent a cable pulling through. But yes the power valves are done.
			Then, if motor is good in all 3 holes, i would guess you have some shot clutch parts, or maybe even some bad drag in the jack shaft, driveshaft or rear suspension.
Also, check motor alignment and center to center on clutches.
Bradthedad
Thank you.
			Bradthedad
1000 feet almost always
			Bradthedad
Hauck thought maybe  I wasnt jetted low enough... I ordered 140s.
			383stroker
What are your egts? Are the vents blocked off in front of the pipes may be they aren't getting hot enough
			Bradthedad
1160 center and mag. Pto was 1060... I have any and all open holes tapes off.... Current mains are 147.5
			383stroker
I haven't had much to do with aaen pipes but have ran a couple stock srx and improved srx on the tar. But why is the pto 100 degrees cooler than the other 2? I know on our stock srx we see 1300 plus egts even 1420 at times but you can't use that as guide you need to watch the piston wash and read the plugs. I would be checking why that one cylinder is colder
			A couple of bucks
My engine runs fantastic at 1200*. Plug chops at that degree indicate good wash too.
							pete_man26
Stock motor, no porting? I have seen bad porting make a sled ALOT slower. If stock, check compression, valves. If they are ok, then move to clutch alignment, from there check your clutching, were the clutches hot? Inefficiency leads to heat, if you can't hold your hand on the clutches then you got a problem. Another thing I like to check is rotating the track, remove the belt and try turning the track by hand.
			Woody255
What RPM were you running? Even a couple hundred over can be detrimental on HP.
			Bradthedad
Yes stock motor
			Bradthedad
I sucked the front suspension way up, drilling new holes in the straps. Loosened the track also. I didnt see the 2nd page. This is my first post.
			Bradthedad
@383 Stroker. Im wondering now how accurate that gauge is. Like you said I need to look at plugs. Sled pulls and pulls, then peaks. Im ready to dump these pipes. I know guys that run 140 mains with stock pipes....I have 146.3 146.3 and 147.5.... I ordered 47.5 pilots also to give her some fuel outta the hole?
			Mac
This is a subject very few people study.  My friends pull the plug and Analyze with the naked eye.  No one ever seems to know what they are talking about as a result of never being taught.  The videos below discuss the reading at the bottom of the ceramic insulator.  Keep in mind you cannot read the spark  standing out on the ice.
https://www.youtube.com/watch?v=O_M5jwSx6jc
https://www.youtube.com/watch?v=uHbhoX0s5_8
							Bradthedad
Nobody's ever told me that... Looks like Ive got homework to do.
			383stroker
I can't see those pipes making anymore than stock. If the stock srx are running 140s you should be save with that jetting or some where close but I would just work your way does slowly to 140s watching the plugs.  Also it be to much finish angle on the helix it pulls hard the goes flat. On the tar we run 50 pilots in out stocker and same with my srx piped viper on the grass
