Has anyone ever swapped a 129 from a SR Viper into a proaction sled ?
Love the look of the rails on the newer sleds, and Im guessing the ride would be better as well.
Anyone have any insight on this ?
Looks like the front slides in instead of bolting up like ours.
Should work, you just need the hole locations from the donor sled off the tunnel from the drivers.
Vincent
What would you do with the funky non boltable front end set up?
You need the cross shaft that it floats on.
Yep, exactly. Was wondering the same thing till I looked up the parts diagram.
There is just a shaft that runs wall to wall inside the tunnel. I'm sure it makes install a bit easier.
Yes very!! I have this on all my Winders, they have the same type of skid in the LTX 137
