if anyone has jetting and a good clutch setup for power inc end dumps i would greatly appreciate it, im running at about 1800 feet on a 01 sxr 700 thanks
Run 146.3 mains right across. Raise needles on mag & centre 1/2 a clip. w-y-w primary spring, 14.5 mm rollers, 89L weights with 2.4 gram rivets, 52/44 helix with green secondary spring at 70 degrees. I have any or all of those parts if you need em. Some sleds run fine on stock pilots but a few need 47.5,s.....just one of those things. Also n
