Installing engine
stealth82
Jefferson, WI
So after getting a new oil pump for my sled and installi g new fuel and oil lines im trying to figure out what goes where. So on the fuel pump on the left side theres three hoses those go the carb. Then the hose at bottom of engine goes to the fuel pump. I have this other hose that comes off of oil pump, and i also got the hose from the oil tank, which one goes to the fuel pump? The engines in the sled so its harder to tell when the oil pump is down in there. Someone help i gotta get this thing running this winter!!
I appreciate the pics, i got the first 3 hoses hooked up to the carb, but now i got the one hose coming from the oil tank and another hose coming from the top of the oil pump, and i cant tell from your pic where those go to?
If it doesn’t look right, we can investigate further, but those hoses should be bent over time to fit in one spot.
Yep, there is a check valve in the line that goes from the oil pump to fuel pump, arrow on the check valve should point twords fuel pump.
