john 89 phazer
I picked up a 1998 Venture 500 at the end of last season. I noticed the low beam headlight wasn't working (high beam was working) so I bought a bulb. Well, that did not fix it. Also, I noticed at the time that the taillight isn't working and the reverse beeper is not working either.
So, I've got no - low beam headlight, tailight, or reverse beeper.
The sled runs and charges the battery at about 13.5 volts or so. The gauge lights work and the brake light works. It has electric start but apparently chewed up the gear before I bought it so they removed the ring gear. The starter turns over.
I am trying to learn more about the regulator/rectifier, it seems as if that could be the culprit? I have an online owners manual that I downloaded and I've been looking for wiring damage. There are 2 fuses by the battery that seem to be for the starter only, they are okay.
Thoughts?
Thoughts?
