Wexcw
Hey guys..i am in the process of swapping the track on this 700 vmax I bought..i found a couple things I didn't expect. The first thing I noticed when I removed the battery to get to the chain case is that on the side on the chain case it has a arm and rod type linkage that's going no where..i am assuming the chain case has reverse? There's no other linkage or shifter..possible a swap in? Also I notice that the pull cord starter housing seems to not fit the engine..it is shimmed out about 1/4 inch all the way around and there's a 3 inch by 1 inch portion toward the back side of the engine that isn't covered by it at all. Not being familiar with these, is that normal? I wouldn't think I should be able to see the flywheel..but I may be wrong..any input would be great!
