Justinmckenzie
1998 venture 700 with reverse. Just changed the track. Put the chaincase back the way i took it off.. or atleast I thought I did. The track moves in reverse (hardly) but nothing forword even with the track in the air. Am I looking for a chan case issue or clutching? Also removed the primary. The belt turns the secondary so I'm assuming the problem is in the chain case. I can move the track buy hand (barely)... Does anyone have a schematic of the chaincase?
Vincent
Chain case... Your Clutching has nothing to do with reverse. Most likely your linkage is out of phaze.
Your 100% sure you reinstalled all the chaincase guts correctly?
4wealn
At the top of the forum page, there is a tech section, go there and then go to suspension/drive, scroll close to the bottom and there is a write up with pics for the pro action reverse install. Have a look there.
Justinmckenzie
Turns out the gear that goes against the drive bearing was backwards
super1c
Super Moderator
Good deal.
