Jimsrx
So I’m setting up clutching on a 99 SRX. It has 8dn-01 weights with 4.5 g rivits in both holes with a Y-W-Y
Primary spring. Secondary is a mountain performance roller with s black spring with green dot. The engagement is about 3800 and ramps up to 8000 great then hesitates a bit
Before max out at 8500. I would like to get rid of the short period of hesitation around 8k.
Any ideas
Any ideas
A couple of bucks
What is the secondary wrapped to?
Jimsrx
It is 3 on roller and 2 in clutch
Try 6 on helix, 1 in clutch
Jimsrx
Ok I give it a shot. Maybe a bit more twist will smooth out the end of the curve.
A couple of bucks
That's exactly my thoughts. Both the primary and secondary springs are battling each other just past 8000 Rs. Hopefully full shift will not move very far.Ok I give it a shot. Maybe a bit more twist will smooth out the end of the curve.
