I need the factory front upper and lower radius rod and tie rod center to center settings. Replacing all this on my sled and all the replacement arms/rods I got do not have the rod ends in them so I have to put them in and set them to the right length
Vincent
I just changed all my front tie rod's, bushings, collars and shocks...
Both my bottom arms were set to 2 - 2.5 threads showing after the lock nut, and tops had 3 - 3.5 threads showing from after the lock nut from factory
There is a center to center measurement. In Hawaii, be back in there days, can give it to you then if you don’t have it by then. If memory serves, it’s around 18 1/4” or 18 5/8” ?
Heading out for the holidays and won't be back until Friday. I can wait and get the dimensions from you after you return from Hawaii and I return from Minnesota
Perfect, thank you.
