Taylorlee101
Hello,
I recently rebuilt my carb and after everything was all put back together it wouldn't fire and I checked my plugs to see that I was not getting any spark. What could be causing this and how can I fix it? Appreciate the help!
Yamahakid01
Was it running before you rebuilt the carbs? Possibly unplugged the coil rack when you took the carbs out?
Taylorlee101
Yes it was running prior to the carb rebuild. The rack is plugged in. Is there anything else I should be checking?
Yamahakid01
Not sure as it has nothing to do with spark. What have you checked so far? Key? kill switch? TORS switch is plugged in or by passed? Other then that check for broken wires. Some are hard to see.
