Mac
Chub  -  Welcome to the site.
The CPR pipes absolutely rip. Did you look through the tech pages for clutch setups? The easiest setup will most likely be a product like Thunder products adjustable weights with a primary black spring 150/300 - Green secondary - 70 wrap that you can setup yourself. Those CPR pipes will make power at 9200-9300 RPM. Good luck and get your jetting right.
---mac--
---mac--
