ttr
Anybody using 89A-10 weights am currently running50/44 dalton with 8dn 20.
I like the 89a-10s..
Vincent
Keep hearing alot about these weights.... Could a 700 redhead pull them? Do you need larger rollers two?
We always ran them on SRX SX the best weight are 8ABs or if you have a pile of mods the 8 CAs
ttr
Could I run those weights with that helix
Yes you should be able too with the correct rivets and springs. Here is more info on a few set ups.
https://totallyamaha.com/snowmobiles/aaTECH/tuning page.htm
