Is it possible to have a copy of the service manual for a 94 Vmax? I paid for the VIP membership, but not showing? I didn’t pay enough attention taking the chain case apart, and want to be sure it is right. Non reverse case.
I thought the thin washer went on the lower shaft between the bearing and gear, then thin spacer/washer/bolt. Top, thick collar inside and out. With a straight edge I am slightly off. If I put the thin washer against the upper bearing, followed by the thick collar/gear/collar, then on the bottom, just the gear against the bearing, thin collar/washer/ bolt, the alignment is spot on. The parts fiche is a bit confusing as it shows a thin washer both top and bottom, and quite sure I only had one. Thanks for any help.
