2” split exhaust rings
MURDER YAMAHA
VIP Life Member
Minot ND
Have a set of bender pipes on my SX.
there are (2) 2” sealing rings on each manifold.
need a set of 6 as mine are wore out.
have had no luck finding any.
not even sure what they are called to be able to do a proper search for them.
need help!
If it's similar to a piston ring, can you use stock rings that are used in the twin cylinder exhausts?
I have had to make them before too.
1. I took the compressor to the chop saw and blew off every bit of sawdust. Then changed the blade out for a metal cut-off blade.
2. I went and found the correct sized pipe.
3. Cut a 1/4"(ish) sized relief the length of the pipe.
4. Then throw it in the saw and slice off the proper thickness.
