2000 srx 700 wot bog
newbie
United States
I have an issue with wot bog, I ran it hard one day 2 years ago and never got it to run right since. Compression is 130 on all 3 cylinders. I replaced springs on clutches, cleaned carbs(I have cleaned multiple carbs and they are done correctly), replaced tors switch on the carbs, new belt, new OEM box sponge filter. Sled starts great idles great and will take throttle as long as I dont wot. When I wot it it sounds like a deep sounding bawwwwwwwwwwww. The throttle cable has plenty of play in it. My only question is there a switch for the tors in the throttle on the handlebar? If so how do u test? I pulled motor in summer and there was no shaffing on wire under motor. I assure u everything I did was done correctly, if there are any other things to check I am all ears.
You don’t mention cleaning or adjusting power valves and making sure the servo motor is working correctly. Tors would not affect you at WOT. Could be upshifting too fast. I would look at your secondary clutch.
