33kartman33
kids little sm292 has lost all spark and i believe the magneto has died. I found a new source coil and a new lighting coil online but wonder if its worth changing. Is there something more modern others are using? Found used mag online as well but would probably end up in the same situation... any help would be great at this point!!! thanks in advance !!
33kartman33
bump..... anybody??? something more modern to use ? As many of these bottom ends being used for racing there should be something....
sry i only had a gs 292 for a short time before i sold it back in the day. could you retrofit a et250 or bravo stator and cdi onto it?
