clutch kit
stang33
Toledo, Ohio area
Can I get some input on a good clutch kit or set up for a '01 SRX 700. She is all stock except for a bender can.
I do mostly hot trail riding and somtimes some short friendly drags on packed trails.
I know there is room for improvment over the stock set up. What do you guys recomend? Any gear changing.
I was thinking of a healclicker kit and maybe droping down a couple of teeth
I have a 02 viper. not the same but similar to what you have
installed a heel clicker clutch kit and dropped down on the top gear 1 tooth.
i lost about 7 mph on the top end but the difference in the power down low was worth it. it pulls much harder off the line and wheelies nice over the moguls.
i think it was a good trade off
heel clickers are different for every sled u set them the way u like them i would recommend heel cickers if u wanna play around with thw clutches other wise through a bender clutch kit in ull see 2 sleds top end and a lot more response down low through a cold air kit in too its only 100 bucks big difference
I have absolutely no idea. i installed them a year ago. the sled is in maine and i am home in boston. start out on what they suggest for a weight (instructions)
screw around from there. simple!!
