Phazer with RPC Over Drive
250Enticed
Sugar Camp, WI
Hello, I just joined this forum today and am humbly asking for help right away. Thank you for the add and I appreciate any help.
A while ago I bought a Phazer with a Reichard's Performance complete overdrive kit on it with a comet primary and an Arctic Cat secondary. I need to replace the primary spring and I don't know what it's supposed to be. The sled also has a RPC pipe on it and the broken spring in the primary is yellow. I'd even take advice on a spring to try even if it's not the same one. Stock motor, just the pipe and flat slide carbs (carbs were also out of the RPC catalog).
thank you again!
If it helps, it has Arctic Cat A1-482 fly weights, which are 48.5 grams, in it.
I see there are two Comet Springs that are Yellow. One is 96-224, the other is 100-187.
You could get a caliper and measure the wire diameter and overall length,any spring that fits a p85 or cat clutch probably will fit the comet to
