All stock except for 1 size smaller main jets. Fuel mixture screws me be a wee tad less than 1,5 turns out.
Where do I start?
Where do I start?
RXMax
More than likely the nozzles are worn. Drop your needles .5 to start
I would check the reeds also.
shaggyzr2
Most of them have the mid range burble, drop your needles a hair
A couple of bucks
Is this the reed notch/spacer burbling you are referring too?
It didn't burble today, it was between -13f and -15f.
A couple of bucks
That tells me it needs to be leaned out a tad. Just like Max and Shaggy mentioned. You yourself just confirmed it though. I'd probably start by dropping the needles a 1/2 spot. Adjust(or not) washer position after you check things out from that run.It didn't burble today, it was between -13f and -15f.
