travinboyle
Hello everyone , first time poster ,long time reader! Hoping someone could chime in on my issues
I have a 1998 SRX 700. Was running good , but i was getting a dim headlight every now and then and an idle surge in RPM. I checked all my wiring harness out and found no rub throughs or shorts that are common with these machines. I also was fouling out the PTO plug lots it seemed , however i went though the carbs and ensured they were spotless but was still fouling plugs.
Yesterday i had the machine warming up. I noticed that the MAG cylinder pipe was cold so I shut it off to change plugs. Once I changed the plug it would not fire. I was getting weak spark.
I have done the following tests :
1- check wiring harness for rubs/broken wires and found nothing
2- Stator output (w/g - w/y) plug to CDI box - unplugged from stator .77 VAC
3- Stator VAC going into CDI box (w/g - w/y) 2.4 VAC
4- CDI output (orange wire to coil plug) 75 VAC
5 - key and ignition shut off switches are working as required - when i turned key off and kill switch down as in off i would get no VAC when pulling rope.
6. There is continuity between all the coils
7. The coil has continuity to ground
I am kind of confused as to where to go from here as i have voltage coming from the source. On my polaris 700 last year i lost spark thinking it was the stator so i ordered a new stator but it turned out to be the CDI. I am wondering if a CDI is the problem here just now sure what wires give the CDI it's power to run the processor in it.
Any help would be much appreciated.
