lil3incher
Any help would be greatful, I have a 2002 Mountain Max 700, I just recently noticed what looks to be injection oil leaking through the belly pan, I removed several parts noticed a Milky looking fluid leaking around the water pump, but it doesn't seem to be coolant, liquid is same color as the oil i use, wondering what would happen if I removed the water pump to further inspect?
Vincent
Doubt it has anything to do with your water pump.
More then likely it's your exhaust header donut or gasket leaking.
lil3incher
Ok I will check those things out, You really think that's what it could be? The fluid is blue like the injection oil I use
Vincent
Where do you figure all that oil that your injection system processes threw your engine end up?
