toddmod
For the past 3 years I've been running my 90 phazer with the plugs in the wrong spot! center and not over pilot! with a terrible mid range stumble! I compensate with the fuel screw adjustment to 3/4 to compensate! It runs ok, but not great, especially mid range. I revisit site to look at possible causes and I see the plug must be over pilot!! Period. Ok, so I pull carbs, go through them, Finally going to fix this long last problem!! put plugs in center and over pilot jet,( good plugs fit nice) turn fuel screw back out to factory spec- 1-1/2. pull air horn side air jets, make sure those passages are clear, put back together......................Will only run with choke!!! seems cleaner until it dies!! but can't keep it running w/o choke!!! What am I missing?? Please Help!!!!
