Chriscraft312
Hi, so I rebuilt the top end of my sx500r last fall and after riding all season I am starting to hear piston slap, or at least that's what I think it is until I can tear it apart again. I believe I honed the cylinders too much and might have taken too much of the coating off. The plugs show no signs of metal shavings and the engine seems to have plenty of power, same as my other vmax 500sx. I am now debating to sleeve the cylinders possibly. This company called LA sleeves has the stock 68mm bore sleeves for 70 bucks each or for the big bore 600cc sleeves for 39 each. Was wondering if anyone has ever converted a 500 to a 600 twin. I think the lower crankcase is all the same but not sure about the head or what you gotta do to the jetting on the carbs. Any advice would help, Thanks guys!
MURDER YAMAHA
VIP Life Member
Bottom end is the same, but IMO, you would be MUCH better off to Ebay a good used set of stock 600 cylinders.
If you sleeve, you will have steel sleeves. Stock is Aluminum - Nikasil plated, much better than steel.
Chriscraft312
Ok, thank you! Didn't know they were steel. I would have purchased from http://www.psep.biz/store/yamaha_snowmobile_cylinder_sleeves.htm which they claim is an alloy of carbon chrome, and molybdenum and to be honest I dont even know what that means. I am gonna try to find a part out 600 around or just 500 cylinders. Mine look ok but I think they lost there tolerance.
Chriscraft312
Do you know if the head stays the same? Also guessing you will have to rejet the carbs and maybe do something to the clutch if its turned into a 600.
MURDER YAMAHA
VIP Life Member
Most will have to change to 600 specs. Jetting, clutching, cylinder head.
You may be able to use stock wiring and CDI, but the 600 has a better timing advance than a 500, so it wouldn't be optimized.
Chriscraft312
Yuck, sounds like a lot of messing around. Think I will just try to find some decent 500 cylinders or send mine in for recoating. At least now I know if I find a problem with the crankcase or shaft I can replace it with a used 500 or 600. Thanks you for the help!
MURDER YAMAHA
VIP Life Member
Yep !
U.S. Chrome does good work, I have sent my cylinders in to be replated a few times.
Then you have the peace of mind knowing they are perfect.
