2001 Yamaha SX700R. Help Please!!
Polarisguy
Wisconsin
I am currently working on a 2001 SX700R. Sled runs perfectly fine, just does not have any electrical power, no lights, no hand warmers, no gauges......I've done some research under google and found that there is a common problem with the wire harness under the engine, I checked that, I have 14.5volts at the regulator while running......I have removed the seat and tank and checked the tail light harness to make sure that wasn't shorted....I removed the handle bar pad and checked for damaged wiring, everything has checked out, I noticed that are two capacitors next to the regulator, idk if there is a way to test them??....Please Help! about ready to pull my hair out. As you can tell by the name, I'm a Polaris guy, just looking at this sled for a friend. Thanks for you time!!
Theres 2 relays by the left footwell, they get wet. Try taking them out and drying them out on a register or something. Worked on my sled
