Different engines in different frames
TrueBlue
VIP Lifetime Member
Looking at replacing a blown engine on my 2002 Viper. Just wondering would there be any other engine that would work in that frame. Does not have to have power valves. It just has to be plug & play. Is it possible to install a SRX motor in the Viper using only a single pipe for the exhaust.
I would think a redhead 6-700 engine would work if you got the wiring harness and electrical stuff with it. The Venom came with a 600 stock. Im not sure, but I don't think an SRX engine would run great with a single pipe. Im not sure if it would even bolt in
you have to run the viper cylinders to run the viper exh. the srx exh ports are a different shape than the viper ones. brother ran a srx motor with srx head and bottom end in his viper with viper jugs. brother is on here under user name kirkswim.
So what was the outcome? I picked up a Viper with an engine with SRX jugs. I haven't checked the case yet. Is there a difference in the cases as well?
