wire connectors
fourbarrel
VIP Lifetime Member
Anyone know what brand,or where to find,the oem wire connectors on the chassis wire harness Yamaha uses for the '00-'02 SRXs? The crimp connectors on the wires themselve are Metri Pack but I can't find the correct square connectors anywhere.There's a number of different ones on the wire harness depending on what's being connected.Most are triangle or 3 blade ones and I do have a link to get the triangle shaped one but haven't found where to get the 4 blade square or other ones yet. Yes I know I can just replace the whole connection with a readily available Weather Pac type but want to stick with factory type if I can.
