fullcoda
roudyroy1
Upper right bolt on the water pump cover, should have a copper washer under it.
fullcoda
Yep, found it, jeeze what an idiot I am. Says drain right on it. Frustrated I guess. Mommy's being a btch, the kids all need spankings and I need a locked door a a couple of beers LOL. Thanks a ton Roudy
roudyroy1
Been there, COVID quarantine is making everyone crazy. Good luck!
There is a small hose (below the large hose) that goes to the carbs. Remove exhaust and run small hose through the opening to drain the motor. It's lower than the drain bolt!
