I have a 2002 Viper 700. I am trying to turn the Carburetor heating knob but it seems that it is stuck in the off position. Does anyone know how to loosen it up. I loosen the bolt above the knob but that didn't do any good. I don't want. to force it & brake it off.
Than's
Rich
Than's
Rich
s10mike
spray it with pb blaster once everyday for 3-4 days, turn it with some channel locks
What is the bolt above the knob for. Can I remove the bolt & spray some pb blaster in the bolt hole to loosen it up.
super1c
Super Moderator
No don’t do that. It’s a fake coolant bleeder hole. Won’t help ya at all. They are very hard to turn, could never turn by hand right from factory. I use channel locks and give it a turn. I just leave it on. Never had a problem.
Thankn you.
EVOVII_SWE
I'm also leaving mine open all the time, I heard that somebody had tested on a dyno and the power loss were marginal, if any.
Vmax xtc 1997
Mine even shut off it will let coolant go through a bit. What is it for any way ? I see that it goes through every carbs.... but what is the purpose of it?
super1c
Super Moderator
Heats the carbs to prevent icing when really cold.
Vmax xtc 1997
ok thank you for the answer
