Hi everyone, I have a 87 Phazer with electric start that I bought in February. Runs awesome so I decided to restore it. The headlight , tail light and instrument lights don’t work, brake light does work. Ground is good, the blue wires are all together but no power. And nothing at the voltage regulator either. Would this be a voltage regulator problem. Any help would be greatly appreciated
Is there any power to the voltage regulator coming from the stator?
i have tested by cheating the system. using a 12 battery, i grounded the negative to the engine and then i put the positive to the supply wire on the dimmer switch. let me find the bad bulbs in my case as i was also having a running issue at the time.
I’ll check for that in the next day or 2 , let you know, thanks
roudyroy1
I’ll try that , thanks
Did this ever get resolved? I am having the same issue
