Hi everyone i picked up a really nice 1998 SRX 600 it has 1400 miles on it all stock and is factory with ohlins shocks.
I'm going to go through the carbs and put new factory stock reeds in it.
I came across a clutch setup on another site suggested by Turk figured i would try to source the parts here before i search ebay and such.
here's what i need:
8bu-oo wights (vmax 4) inner hole empty & 2,4gram rivet in tip
45/39 helix
Sliver secondary spring.
please let me know if you have any of these items
here's what i need:
45/39 helix
secondary spring is taken care of thanks srx700c!
A couple of bucks
The 8BUs,8CAs & the 8ABs are all the EXACT same profile. Each one just weighs slightly different. Now having mentioned this and knowing that 2.4g are only going in the tip .... you could also use the 8CAs. Just adjust that 2.4g rivet to something heavier.
https://totallyamaha.net/showthread.php/107602-3-NOS-Yamaha-snowmobile-CLUTCH-WEIGHTS-8CA-17605
A couple of bucks
8BUs + 2.4= 47.81g.
8CAs + 4.5= 47.3g.
Washers on the rivets will fine tune the set-up.
8CAs + 4.5= 47.3g.
thanks for the info! definitely gives me some options!
