Clutch set up comparison
MYRODMAN
new boston,ill
Was looking at the TY clutch user charts and someone has a 2000 SX R 600 that they used 8AB-00 weights wit 2.4 in the 1st hole a Y G Y primary spring Dalton 51/43 helix with red secondary spring set at 60 or 70 degrees. Will this work on a 2000 V Max 600 ER?
Check whether the gearing is the same. Also, do you have the same track lug height as stock? That being said, these are very easy to clutch.
Thanks Norwegian I looked up the gearing and it seams they are the same 22/68 The track lug height is stock The factory clutch set up is really soft and slow Looking to fix this and my 13 year old grandson is going to grass drag this in a few weeks Your help is really appreciated thanks again
