Hi everyone! Hope someone can help me on this one..
A few weeks ago I sold my 1996 V-Max 600XT to a friend, since I bought a brand new RX-1 . Anyway, I knew that one of the rollers in the primary was busted, the bush inside one of them was practically gone, and that roller also has a groove in it. The weight going against that roller was also "grinded" off.
I told my friend to not worry and that I would order new parts for him, and so I did, new weights, rollers & plastic washers.
I friend came over and I started working on his primary.
When I was about to install the new weights I discovered that there were no rivets in the new weigths, wich made them 4 grams lighter then the old ones. (the plan was to order rivets and put them in asap).
Another thing I discovered was that the collars that the rollers / weights "slide" on, where sliding back and forth, the collar seemed to be to long , (I figured this would have to be where all the noises that the primary had been making, came from), so I measured on the primary to find out how long the collars should be so that it made the nut on the bolt almost hit the primary, reducing the back and forth movement of the collar that probably made alot of noise.
Anyway, I installed all the new parts, I checked that all the weights and rollers were moving freely and everything seemed perfect. When we started the sled, the primary seemd more noisy then before.
We went for a ride, only about 10kilometer, and when we came back I decided that it would be best to put the old weights on until I got the rivets for the new ones, it rewed way to much and didn`t "engage" before 5.500rpm.
HERE`S THE PROBLEM :
When I took of the weights I inspected the new rollers, non of them where moving freely. The bushings inside them were a mess, totally ruined. What could possibly have caused this?.
I`m wondering if my collar cutting could have caused it?, it shouldn`t since all the rollers where moving perfect even after the collar cutting... (I thought I had to mention it, just incase).
The only solution I saw was to put back all the old parts, which was pretty annoying, having spent about 260$ on parts. I know I can use the weights when I get the rivets, but still.
The new parts
The highest speed this sled reached this weekend , was on the trailer ..
I added the pics to great some more interest, I really hope someone can help me, I`m only a kid (19year`s old hehe) from the North of Norway, so I need help from the pro`s in US.
Joakim.
The new parts
Joakim.
